The Arm Partner Catalog
The Arm Partner Catalog is the B2B marketplace for your Arm-based solutions and the center for all ecosystem partners on Arm.com. This makes it the ideal place to connect with Arm partners and a thriving hub for co-marketing opportunities.
The Arm Partner Catalog is also one of the top assets for members of the Arm Partner Program on Arm.com, giving your company and solutions enhanced visibility to the leading Arm ecosystem.
Here are some of the key metrics for the partner catalog:
Among the top 20 most visited arm.com assets
50 percent of visitors are returning visitors
Growing month by month, including all Arm ecosystem partners over time
If you are looking to find a partner in the Arm ecosystem to help you create your next product, check out the Arm Partner Catalog.
Each Arm partner is required to have a catalog page and update it at least once per quarter. Here's how to create your own page:
Head to www.arm.com, then click the person icon on the right-hand side (see image below).
Verify email address using confirmation email sent from Arm.
Send email address used to register to Tobias McBride.
Tobias McBride will send over the link to the Catalog Portal to create your page, as well as the Solution Brief template that is required to be completed for at least one market segment.
This how-to video guide below provides you with step-by-step instruction to create or update your page once you have an Arm account created, and also outlines the required image and PDF sizes and dimensions.
Size validation checks are built into the form whenever an image or document is required to be uploaded. Please check these when uploading any images or documents to the form. The video guide (left and below) outlines what those are, so please review before submitting your content to the form and ensure images and PDFs are compressed and the correct size in order to reduce review time.
Validation checks are built in for text length and character count, so please ensure that the entries in all fields do not exceed the character count.
If you click the link to the Arm Partner Catalog portal, login and get redirected to arm.com, simply copy the link to the form from the email and paste it again in the same tab window for it to open.
The content form will be blank if you don't have a catalog page, and it will pre-populate with existing content if you are an existing partner.
Please use unique file names. Do not upload files/images with duplicate names in the same form section (e.g., two headshots named “Jane Smith.jpg”). Each file/image name per form section must be unique to avoid being overwritten.
Please do not use any special characters (e.g. _ * - [ ]) in the files names.
Make sure you press “submit” once you have made all of your changes/updates.
We suggest you open another partner’s catalog page if you don’t have one (or your own catalog page if you do) in another tab to see the different locations for content. The video guide also describes where each content item lives on the page.
If you have any further questions, please contact Tobias McBride, Arm Partner Catalog Product Manager, via email.
