Take full advantage of %Company_Name%'s Arm subscription with all the solutions and technologies available in your package.
What is Arm Total Access? Arm Total Access opens the door for you to the latest Arm technology – hardware IP, software, tools, and support – via %Company_Name%'s subscription.
Every quarter what is included in %Company_Name%'s package is updated based on the subscription level %Company_Name% has chosen.
The following chapters explain what you have access to with your package as well as what is new this quarter. If you need a reminder on how to access the technology, please check out your starter's guide.
Arm Confidential Information
Arm Total Access Subscription tiers are based upon several usage scenarios. The first axis is based upon which types of IP is most often required by %Company_Name%. The IP included in Package B also includes the IP in Package A. Package C is inclusive of IP in Package B and Package A.
The second axis to which your subscription tier is based is product development status. %Company_Name% has chosen whether the IP available to you is in earlier development stages (EAC/LAC*) or later at full release (REL*). For subscriptions to the Regular tier a built in limited use license (LUL) is included for evaluation purposes.
More details on these stages of product release can be found in the glossary.
Early Access EAC Hunter-ELP COrtex-X3 (Makalu ELP) Cortex-A715 (Makalu) Mali-G715 (Turse)
On Request Mizar
Available in Main Package
GIC-700r1 Mali-C71 Mali-C78 CMN-650r2 COrtex-R52+ Cortex-R82 Cortex-X1C (Hercules-ELP Prime)
Cortex-M85
A step-change in efficiency for the IP selection process when defining a custom System on Chip (SoC)
Full details can be found here
Arm Total Access members are invited to preview the beta version here
NEED SNAPPY HEADER
The third axis to which your subscription level is decided is the consumption tier. Depending on the level which %Company_Name% has chosen, the number of projects and in which package the IP can come from will vary. Consumption is measured by how many active projects (between committed and mass production) can be developed concurrently.
Package A
0. Roadmap
New page
