Design Quickly With Confidence
See how your membership can help you accelerate innovation, reduce risk, and ensure your product succeeds.
Our foundational technology is defining the future of computing by making it possible for hardware engineers and software developers to bring their visions to life and turn unique ideas into reality at scale and fast. To do this, we provide a wealth of development tools and support to help you implement our IP quickly, smoothly, and successfully.
Arm Flexible Access for Startups provides easy access to a wide range of proven and verified IP backed by Arm's tools, training, and engineering support. This means you get all this, and more:
Freedom to experiment with IP before committing to production.
IP that uses widely adopted interconnect standards, making it easier to collaborate on designs with third parties.
SoC performance that can be accurately predicted using modeling tools provided.
Free libraries of Artisan Physical IP optimized for performance, density, power, and yield, and available for multiple foundries and process technology from 250 nm to 5 nm.
Build with Confidence
Avoid rework and delays with projects delivered on time and within scope. The following additional features in Arm Flexible Access for Startups are proven to help you accelerating time to market and increase the pace of innovation.
In addition to the extensive IP included in your package, Arm also provides additional tools, models, and software in Arm Success Kits. Everything provided is aimed at enabling you to adopt and integrate Arm technologies with confidence.
Arm Success Kits are a fast way to access licensed tools and models for both hardware and software development. Developed for flexibility with modern software development environments in mind, the kits are optimized for maximum throughput in continuous integration and regression testing environments, and are ideal for enabling cloud-based tools and models usage.
Designed for easy access to Arm tools and models, encouraging IP exploration, and helping drive innovation.
Tools and models for all of the Arm IP are included, enabling designers to choose the best IP for their products.
User-based licensing makes it simple to plan for and manage by requiring only one license per user. Provisioning is automatic, eliminating administration overhead.
Each user has unlimited access to all the licensed tools and models for optimal productivity and efficiency.
Developed to be flexible with modern software development environments in mind.
Optimized for maximum throughput in continuous integration and regression testing environments.
Ideal for enabling cloud-based tools and models usage.
Start your SoC design journey with Arm IP Explorer to discover which IP is best fit to meet your product requirements. Ideal for SoC architects and system integrators, Arm IP Explorer is a cloud-based platform that helps increase efficiency and productivity. Users can make high quality IP selection choices and quickly create block diagrams, while reducing cost and time to market.
Explore
Discover Arm IP which matches your project requirements
Compare key IP differences with ease
Simulate CPU performance for your custom workloads
Design
Configure Arm IP easily in the cloud
Create block diagrams of your SoC and verify AMBA-level compatibility
Start from sample designs built by Arm experts
Connect with design partners to help create your SoC
Automatically generate IP lists and license information from diagrams
Collaborate with stakeholders using shared projects
